help locking down flywheel
i am doing a cam swap and i just need some help figuring out how to lock down the flywheel to remove the crank bolt. ls1 how to says just to jam a screw driver in there i did a search but cant find anything more spacific can anyone help a frustrated noob
crawl under car, remove circular looking inspection cover plate. take largest flathead screwdriver you have and jam it in there between the flywheel and tranny while your helper breaks the bolt loose. it will take some time to get the right position but it will work. trust me i did it 1 day ago.
i wasn't impressed with the kent moore's price tag but i will admit it worked perfect and the motor wouldnt budge. if you can swing it i say go that route.
