LS6 cam ?
Old 09-23-2003, 09:15 PM
Red01Chevy's Avatar
Default LS6 cam ?
if i were to install a ls6 cam into a 2002 z28 do i have to change the valvesprings or pushrods
13.18@105 untouched
Old 09-23-2003, 10:27 PM
someday's Avatar
Default Re: LS6 cam ?
u hafta change the springs, the LS6 cam has ~.550 lift vs ~.480 of the stocker...
Old 09-23-2003, 11:05 PM
jmX
jmX's Avatar
The pushrods can stay stock, the valvesprings need to be changed. I'll be installing LS6 cam and springs probably in the next week or so. Should be interesting to see what it does on a bone stock car with just a lid.
Old 09-23-2003, 11:07 PM
I can shift faster than you.
Jason99T/A's Avatar
Dyno??
Old 09-24-2003, 06:11 PM
Red01Chevy's Avatar
jmX could u please post times or dyno results after instalation
13.18@105 untouched
Old 09-26-2003, 12:36 AM
lsx24's Avatar
Are you aware that you won't gain any power at all over the stock cam until about ~4k rpm? If I were you, I would go with something larger since you're going to go through with it anyway...there are many grinds that will have great drivability and make much more power. Just my opinion.
Old 09-26-2003, 02:15 AM
blk~2000~Z28's Avatar
You need to read JimX's post. This cam must be problem free and cheap. i.e no lopey idle and no empty wallet.
