Cam install Q
Old 09-23-2003, 11:14 PM
BadAndy's Avatar
Default Cam install Q
Should I swap the springs before I swap the cam or after?
Old 09-23-2003, 11:25 PM
SSactionLs1's Avatar
Default Re: Cam install Q
doesnt matter
Old 09-23-2003, 11:32 PM
2xLS1's Avatar
Either way. It doesn't matter. The rocker arms are going to be off when you spin the cam to push the lifters up so it won't matter if the springs are changed yet.
Old 09-23-2003, 11:33 PM
jmX
jmX's Avatar
Doesn't matter what order you do it in as long as you don't run the motor until the springs are done.
You could do springs one day, go back in a few weeks later and take care of the cam. They are almost 2 seperate jobs.
Old 09-25-2003, 01:31 AM
BadAndy's Avatar
Great wrrite up, JMX. Except you left out the part about how that damn A.I.R. fitting is bolted on top of the driverside coil packs and bolted again in between the head and firewall. That was a bitch. I also just about blew shotgun holes in my radiator
Old 09-25-2003, 04:16 AM
hey JMX...i started my cam/Intake man swap tonight...just did the tear down...i DID get lost on how to disconnect the drivers side hose right behind the TB that goes into the manifold..it has a strange fitting...if u can add that somewhere it would help...otherwise its all good playa
Old 09-25-2003, 10:01 AM
BadAndy's Avatar
true playa fo real
Old 09-25-2003, 02:57 PM
TaTommyWS6's Avatar
I would swap the springs AFTER for one simple reason. In the nightmare case you drop a lifter during the cam swap, the heads have to come off anyway. Why break your *** doing springs in the car if you have to wind up pulling the heads anyway?
Tommy
