heads and cam (PRC VS Patriot)
Hi , we are planning for heads and cam but we are puzzled between those two , TSP Stg 2.5 LS6 Heads and MS4 112LSA , Patriot LS6 5.7 - STAGE 2 (2.055/1.57/59cc) and LG G5X3 112LSA , what of those two combos will give us more power ? any results , videos , dyno graphs
best regards
best regards
you would most likely have to flycut the pistons with either setup.
What are you wanting to do with the car. if you spray then MS3 if NA then the MS4.
I am always about running a smaller cam while bumping up compresson with a smaller CC head. be at the same power level but and make usually more power under the curve.
