Prying off LS1 oil pan...HOW?!?
Old 11-30-2008, 09:04 PM
quickblue2's Avatar
Default Prying off LS1 oil pan...HOW?!?
Where is everyone prying off the oil pan? I can find anywhere to get this thing off...
Old 11-30-2008, 09:44 PM
djsanchez2's Avatar
Tap it on the sides with a rubber mallet it should wiggle loose w/o damage.
Old 11-30-2008, 10:08 PM
S10xGN's Avatar
If you get all the bolts out, it ought to practically fall off...
Russ
Old 11-30-2008, 10:12 PM
andrew69_04's Avatar
Russ
X2
shouldnt take much for it to come off. make sure you get ALL the bolts. There are 2 long bolts at the back of the pan, make sure you get them.
Old 11-30-2008, 11:26 PM
scottHMT's Avatar
+1 on the two long bolts on the back of the pan, i think they go through the trans aswell. I didnt know this and i just bent my pan down to get the oil pump bolt off, im lucky it didnt break.
Old 12-01-2008, 06:59 AM
forcd ind's Avatar
def look all the way in the back-2 long bolts go thru the rear cover, and 2 reg thru the front cover besides all the side bolts
Old 12-01-2008, 08:47 AM
Dragkid1917's Avatar
wordd^^ Had same problem... Deffy still bolted up someware because the pan gasket sure doesnt stick very hard.
Old 12-01-2008, 09:06 AM
the_merv's Avatar
It comes off pretty easily..
Old 12-01-2008, 12:48 PM
snake charmer's Avatar
there is not much room with the kmember even if all the bolts are off . remove the bolts in the engine mounts . take a jack with a block of wood and place it where the balancer goes and slowly jack it up some . also if the intake is on it may get in the way . just make sure you are very careful .
this should give you enough room to do what you need . i was able to get the number 8 lifters off a car using this method . they were on top of the windage tray which is above the oil pan and still there is not much room .
Old 12-01-2008, 08:57 PM
GM WORLD CLASS's Avatar
the pan should just fall off once bolts are removed. if clearance is an issue i just unbolted the cradle and lowered it down about 5 or 6 inches and it came right off. i wouldnt pry on anything very much if at all. those pans WILL break
Old 12-01-2008, 09:42 PM
Randy WS6's Avatar
I would do what GM WORLD CLASS said , drop the K member , just six bolts on the K member and four sway bar bolts , two motor mount bolts, and doun i come, just support the engine
Old 12-02-2008, 01:47 AM
TireSm0ke's Avatar
Whats the best way to support the motor? A block of wood on the balancer? Doesnt seem like the best way to do it to me, correct me if im wrong. I gotta change my oil pan gasket soon.... Also do you have to remove the shock tower bolts?
Old 12-02-2008, 04:48 AM
Randy WS6's Avatar
I supported mine with a piece of wood off the balancer ,wont here any thing, And no you dont haft to remover the shock tower bolts
Old 12-02-2008, 01:27 PM
well i work at a shop so i used engine support j-tool that sits above the engine. (not helpful sorry) a screw jack or jack stand under the balancer would work, just pat attention to whats goin on to be sure nothing is being damaged. those gaskets are metal and tough rubber. they should not have to be replaced every time removed. that is unless you are leaking.
Old 12-02-2008, 02:04 PM
gpainnt's Avatar
just did mine took forever until i looked on this post (the two bolts going through the tranny)
Old 12-02-2008, 02:47 PM
TireSm0ke's Avatar
Yeah mine is leaking, so I gotta change it out. So let me clarify: Jack up engine from the balancer with a piece of wood/ unbolt motor mounts/loosen (or remove?) 6 K-member bolts/ jackstand under balancer... Is this all that needs to be done? Im just confused about how to support the entire motor, would jacking it up from the tranny bellhousing and a jackstand under the balancer be more stable?
My other question was rod bolts. Some people say if the pans off just change them, some people say you cant change them without doing the whole rod.... whats the truth being this?
And btw sorry to the OP for hijacking your thread lol... hope you found this useful
Quick Reply: Prying off LS1 oil pan...HOW?!?
