timing chain dampener
Old 12-01-2008, 08:48 AM
forcd ind's Avatar
Default timing chain dampener
are any of you guys using this thing-i was gonna put one in my new motor, but after pricing it from GM, i'll prob just stick with a double row chain, lol
dont know if it really helps, esp with a good chain thats tight
Old 12-01-2008, 11:17 AM
vettenuts's Avatar
The LS1/LS6 damper is no longer made and pretty much impossible to find. It does prevent chain wrap around the crank sprocket, which is an issue with an LSx motor at around 4,000 RPM or so. Double chain will not prevent this problem, but it is mostly seen by those who road race as there is much more time spent at these RPM levels. I know someone who just broke his second chain (double) due to this problem and he just scored a used damper to install as he couldn't find one.
Old 12-01-2008, 11:36 AM
forcd ind's Avatar
i had called my buddy at the chev dealer, and he gave me a price, but i didnt ask him if it was avail-maybe its no longer avail thru them-i'll ck with him later
the part # i had was 88958607 for the kit, around $110
Old 12-01-2008, 05:18 PM
vettenuts's Avatar
Yep, because GM never installed it on the line it was only available through GMPP in limited numbers. The newer motors have it from the factory, needless to say GM is making tons of them and the price is $10. Won't fit older motors though.
Old 12-01-2008, 05:30 PM
silverLSWON's Avatar
the ls2 wont work?
Old 12-01-2008, 06:34 PM
vettenuts's Avatar
Originally Posted by silverLSWON
the ls2 wont work?
No, bolt spacing is different.
PS: I contacted Robin at GMPP who is on this board to find out if they could start production again. Haven't hear back from him as of yet but if you PM him as well he may understand there are quite a few guys trying to obtain this part.
Old 12-01-2008, 07:21 PM
SOMbitch's Avatar
I think they were actually in the first 97 ls1's in the vette but discontinued after that.
Of course that does nobody any good....
Old 12-02-2008, 07:10 AM
forcd ind's Avatar
i wonder why its a problem with LS motors, in 40 years with s/b's i never had a problem with timing chains(except those dam plastic ones the factory used)
when i built this LS motor i used a comp cams one, seemed fine-i did have a factory setup i bought, single roller, and when i installed it, it was just to loose for me, so thats why i switched-i still have all the GM part #'s i used on the single roller, maybe i had a mis match, i think the cam gear was for an ls2 front cam pickup sensor
Old 12-02-2008, 09:58 AM
SOMbitch's Avatar
Yea those old nylon chains would stretch. I had one jump time and backfire through the carb and catch fire in 70 Olds Cutlass
