PTV Clearance measurments
Anyone with This setup have any PTV measurements or clearance issues? As i do not want to have to flycut. Im pretty sure I should be Ok without fly cutting but have been warned by a pro to check with others with the same setup and see what the measurement is. Below is my Setup I also calculated my DCR to be about 8.7. Thanks for any help guys!!!
PRC 5.3 stage 2.5 heads milled to 59cc
TSP 224R CAM 224/224 581/581 112LSA
GM MLS HEAD GASKETS
PRC DUAL SPRINGS
GM MLS HEAD GASKETS
PRC DUAL SPRINGS
To the OP, if this is a concern you need to measure without a doubt. Too many tolerances and if the cam is off a degree or two advanced that will take out intake clearance and vice versa for the exhaust. I wouldn't depend on what someone else measured as the consequences could be catastrophic.
Yea Im hoping it will be ok, I can't wait to get this bad boy up and running, My tuner Steve at lsx tune says she should pull real hard down low. Just for added measure I got my GF to give me the money for a used fast 90/PTM90 setup that I bought off a guy on here. My next step is to find a nice 12 bolt with some 3.73's and a true trac and slap it under the car!!!
