Stock valve covers
Stock valve covers
I know that Jesel shaft mount rockers will not fit under a stock cover but will everything else? I'm going to run Comp Pro Mag 1.85 and i want to be prepared when I install them. Thanks for the help.
my harland sharp rockers cleared the covers fine, although i had to clearance the inside of the gasket surface on the heads. that edge just barely touched the back side of the rocker.
there is a company that makes valve cover spacers for the ls1...although they are $$$$$$$$$$$$$$$
still cheaper than new cover though
