Will LS6 heads clear a 5.3 bore?
Just wondering, a buddy and I are swapping an LS based engine into his M3 and we were wondering if we could put LS6 heads on an aluminum 5.3 block. Thanks!
Chances are that the cam will not clear those heads. If they have a larger than stock valve in them, the cam will not clear. What other bolt on's are done to the car? What are your future plans and goals out of it? Let me know and I will see if we can set you up with a cam to meet your needs!
Thanks!
Jon
Thanks!
Jon
in the middle of my ls1 mustang swap
would like to be able to run 10s all day long and drive home, to the store, movies, etc its going to be my daily driver. street car.
z06 flywheel & clutch t56 6speed
stock ls1 short block
stock ls6 243 heads p&p apr studs
ls6 intake p&p
ls6 injectors
ls6 rockers
ls6 intake p&p
ls6 injectors
ls6 rockers
