ARP head studs torque spec wanted
Old 12-07-2008, 07:30 PM
stangs4sale's Avatar
Default ARP head studs torque spec wanted
I am looking for ARP torque spec for there LS1 head stud kit. I have heard 22ft/lbs on the top 5 and 85 with the bottom 10(with 10-30w oil) Any help would be great.
Old 12-07-2008, 07:36 PM
Sammyboy's Avatar
You torque them in a series and at several different specs...check LS1howto.com
it will show you there.
Old 12-07-2008, 07:55 PM
scottHMT's Avatar
i wnet 76 on the headbolts, seems to be holding up. kinda wish i went to 80
Old 12-07-2008, 08:28 PM
addicted2myWS6's Avatar
That is how I have always done them, no problems.
Old 12-08-2008, 04:54 AM
vettenuts's Avatar
Using ARP Moly (which I strongly recommend) the specification is 80 lb-ft. This value was revised last January.
Old 12-08-2008, 03:01 PM
brad8266's Avatar
Its 80 ft-lbs with moly lube. I did 85 lbs when the specs were 70lbs. I like the extra clamping force. 25 on the small upper studs.
Moly lube is recommended by ARP and the torque specs will change based on if you use it or not.
