Damaged heads, are they repairable? Pics inside.
Old 09-25-2003, 03:06 PM
66ImpalaLT1's Avatar
Default Damaged heads, are they repairable? Pics inside.
I have the opportunity to pick up a set of ported heads very cheap, but one of the chambers has a lot of damage. Is this repairable, how much do you think it would cost?
Thanks,
Eric
Old 09-25-2003, 03:17 PM
Heretic's Avatar
Default Re: Damaged heads, are they repairable? Pics inside.
Thats nothing that won't buff out.
Seriously, it looks like one of those things that if you have a TIG, and know how to use it you could repair easily. However, having to pay someone else to do it, you might be better off buying undamaged heads.
Old 09-25-2003, 03:35 PM
2001CamaroGuy's Avatar
it does not look all that bad.....what happened?
Depending on how much you are getting them for and how good of a port job they have, they could be a good deal. That cylinder would need to either be welded and re-machined or all the chambers need to be "ported out" (more cc's).
I would expect to pay someone to fix them, just trying to figure out if its worth it.
Old 09-25-2003, 03:54 PM
Colonel's Avatar
Those can be fixed for sure.
Old 09-25-2003, 04:43 PM
robertbartsch's Avatar
Alumium can be repaired much easier than cast iron....looks like you could have these fixed... obviously, you need some new valve seats,,,
...I've even seen the NHRA guys re-use alumium heads and blocks that have been heavily damaged....
Old 09-25-2003, 05:18 PM
Visceral's Avatar
Jeez... the heads on my car have looked worse than that a number of times :/
They always came back looking new. Sometimes some of the other chambers might need material removed and the head might need a tiny bit of milling to reatin a good CR. Nothing expensive.
Are they LS6 heads? I cant see that far. If thye arent, it may not be worth it. If they are...what the hell...the porting job should do alot of the cleaning up.
chris
Old 09-25-2003, 05:36 PM
Krazy98Z28's Avatar
does look like the heads i sold.
What kind are they???
Old 09-25-2003, 10:05 PM
SLowETz's Avatar
Give Brian/Brent at TEA a call. They'll send 'em back lookin'/flowing like new
Old 09-25-2003, 10:46 PM
ne14a6t9's Avatar
I would have them flow checked first to see if they are even worth the effort
Old 09-26-2003, 08:35 AM
SLowETz's Avatar
We're sure you would....
TEA can fix 'em..... period.
