heads/cam setup question!
Old 12-08-2008, 11:16 AM
L$1W$6's Avatar
Default heads/cam setup question!
Will my ASA 226/236 525/525 110 LSA work with some PRC 2.5 5.3L heads (unmilled/2.04/1.575 valves) without having to flycut? This setup is going on a stock bottom end LS1. What gaskets to use? Need some info asap!!!
Old 12-08-2008, 10:48 PM
tacklebox's Avatar
It seems like it should be ok with only 525 lift. Put in some .040 gaskets if there's enough ptv clearance.
Old 12-08-2008, 11:15 PM
First Collision's Avatar
should have plenty of room
Old 12-08-2008, 11:36 PM
L$1W$6's Avatar
Thanks for the help guys. Im actually looking at another cam now. I was going with an MS3 but the heads werent setup for it. I bought them used. So now I need to find a replacement. Any ideas? I don't want to flycut either!!! What about the 228R cam from TSP?
Old 12-09-2008, 01:12 AM
zx9rgreen's Avatar
You should contact TSP, They are super friendly and quick to respond.
I am waiting on my 224/236 @ .609/.607 111 cam to come in. Going with the PRC 2.5 5.3 heads also with the larger valves but originally machined for the MS3. I milled the heads 0.020" and TSP "Thought" I should be safe with PTV. But I am going to measure it as soon as my cam shows up, I'll post up my findings when I am able to.
