What is max lift for ls6 springs?
Old 12-09-2008, 01:48 PM
tennerv8's Avatar
Default What is max lift for ls6 springs?
I picked up some L92 heads and was looking into getting some valvesprings for them. I always thought ls6 springs were good up to .550 lift. But I stumbled on a site that sells them and they say up to a .580 lift. The cam I will be using is a .573 lift. Which is it, .550 or .580? Thanks fellas.
Old 12-09-2008, 04:13 PM
tennerv8's Avatar
Or would I be better off with some comp 918's or some pac-1218's?
Old 12-09-2008, 05:36 PM
JBIRD02's Avatar
I believe the older ones were .550, and the newer ones (cause there was a revision in '02 I believe) are rated at around .570-.580
Either way, you're right at the limit so I wouldn't push it. Just get some 918's.
Old 12-09-2008, 08:07 PM
highgear's Avatar
Lingenfelter uses them on their cams in the .570-.580 range street cams. GM says they will go 100K miles. I've had my LS6 springs on since 2003 and they are still good.
Old 12-09-2008, 08:15 PM
davidz28man's Avatar
Default ls6
the yellow ls6 one are 550. if i were you id b safe and go with the 918's
Old 12-09-2008, 09:19 PM
SSTYCOON's Avatar
according to summit ...570
Old 12-09-2008, 10:30 PM
JBIRD02's Avatar
Actually, the yellow springs are the newer ones.
Blue are the '01 & older rated @ .550
Yellow are the '02-'03 rated @ .580
But, I agree....go w/ the 918's
Old 12-10-2008, 03:03 AM
PREDATOR-Z's Avatar
the intake valves on L92 are too heavy for that spring and high rate cam. Better get a stiffer spring.
FYI, you do not only look at lift capability of the spring and say this will handle X or Y cam. You have to look at spring pressures and install height.
Old 12-10-2008, 10:57 AM
tennerv8's Avatar
Great guys. The heads are currently bare. I bought them bare so I can put the parts I want in them. I was thinking about getting some Ls3 valves. I hear they are suppose to be lighter and will go right in these heads. I also heard there was some faulty 918's sent out. Like there was a bad batch so to speak.
Old 12-10-2008, 03:46 PM
11 Second Truck Club
MPFD's Avatar
Ferrara Valves and Pac Beehive 1218's for an L92 setup would be ****.
Old 12-10-2008, 05:14 PM
Blk_Ws6's Avatar
918= what lift?
How much?
Old 12-10-2008, 05:17 PM
tennerv8's Avatar
Who has the Ferrara valves? What is the weight of them?
Old 12-10-2008, 05:58 PM
01ssreda4's Avatar
pac 1218s
Old 12-10-2008, 06:06 PM
180ls1's Avatar
just what i was going to say
Quick Reply: What is max lift for ls6 springs?
