High oil pressure!!! help
Hi guys, Im having a problem with high oil pressure.At idle the car sits alittle over 60psi. at wot it sits around 80+psi, i have used 5w-30, 10w30, with no avail. what is causing this, could it be the relief valve in the oil pump????
any help is appreciated, Thanks
check your PCV system but i dont think you have a prob there. It takes alot to blow out a rear main like that. Im thinking more along the lines of possibly a groove or something on the sealing surface of the crankshaft or possibly a rear cover problem. Rear main seals dont usually go bad that much on these engines but lots of rear cover problems. If you do it again i would replace the whole rear cover and make sure you are installing the seal properly
Thanks for the info, i put a new clutch in it about 10 thousand miles ago due to leaky rear main, replaced the rear, pilot, and put a new clutch in it. No problems until now, and only when i spray does the clutch pedal fall to the floor!
I found out that the rubber hose that the pcv valve connects to is in pretty bad shape. It is the larger hose that has the ground strap attached to it,seems to be leaking pretty bad, could this cause high crank case pressure?
