which cam to use with patriot stage 3 heads
Old 12-11-2008, 12:34 AM
ALPz28's Avatar
Exclamation which cam to use with patriot stage 3 heads
looking to get around 500 hp to the ground when its all said and done but need some advice on which cam to use with the stage 3 patriot heads. want an aggressive cam with great numbers but thats not over aggressive for driving purposes. i have other parts for project but need help picking the cam.
anybody have a proven setup with stage 3 patriot heads and cam?
Old 12-11-2008, 01:07 AM
PowerTalk's Avatar
500rwhp?
Better buy a 4.125" crank too
Old 12-11-2008, 01:42 AM
ALPz28's Avatar
yes rwhp but sounds more dramatic to say to the ground lol. just looking for people that have proven setups with these heads and which cam they used and their outputs and 1/4 miles times if possible.
i like the fms fm113 cam but want more intel.
Old 12-11-2008, 09:39 AM
5.3LJimmy's Avatar
The stage 3 heads are for larger than stock bore/strokers. What size engine are you putting them on?
Old 12-11-2008, 09:42 AM
on2
on2's Avatar
With the right combination...G5X3, MS3, MS4, LSR 54-460-11, VRX6, SI6, SI7 can get you there or close while retaining driveability, but if you want to be sure get a custom spec from Patrick G.
FMS F13 will get you there if you have trick items like dry sump, ITB's, otherwise you will need bigger like an F15.
What are the specs on those heads?
Old 12-11-2008, 10:43 AM
5.3LJimmy's Avatar
Here is the "recipe" https://ls1tech.com/forums/generatio...heads-cam.html
