Changing set up need help
Old 12-14-2008, 06:59 PM
Zach79Z's Avatar
Default Changing set up need help
I recently planned a set up with the vrx5 cam and decided to change to a custom grind cam. I was hoping yall think i would run into any problems with this set up.
Stock bottom end ls1
Comp Cam- 230/230 .612 .592 111+2
TSP ported Ls6 oil pump
Comp 850-16 lifters
Comp Chromemoly 7.4" Pushrods
241 heads ported with stock valves and 220cc intake runner
TEA Dual .650 lift dual vavle springs
ls2 Timing Chain
LS6 Intake
FAST 36lb Injectors
YankSS3600 Stall
3.73 Gears
Texas Speed 1 7/8 Lontubes
Cutsom Y and Loud mouth with sweet thunder
Ill also be using all stock gaskets
Old 12-14-2008, 07:10 PM
zracer323's Avatar
Sounds like a good setup...should be good for high 11s
Old 12-14-2008, 07:11 PM
1999ssls1's Avatar
Thats a pretty good setup. I would use the ls7 lifters instead of the comps. IMO
Old 12-14-2008, 07:12 PM
Zach79Z's Avatar
Thanks. Im hopping for 11's
I planned on using the LS7 lifters orignally but i was suggested to use the comps cause they are quieter
Old 12-14-2008, 07:22 PM
cyacops's Avatar
i'm not 100% sure but i heard that tsp was having problems with fitment on their headers
anyway nice setup
Old 12-14-2008, 07:24 PM
Zach79Z's Avatar
I talked to john i believe it was at TSP and they siad the problems there are is with older motor mounts bein sluggish on the older cars. He said newer modles have chromemoly and dont have that problem
Old 12-16-2008, 02:03 PM
Zach79Z's Avatar
Been told to mill the heads a little to increase compression. Anyone have any suggestions on the milling? After talking to a few people we came up with the possibility of milling .015 and running a .040 gasket.
Any input?
Old 12-16-2008, 02:35 PM
regency's Avatar
mill .020 - .025 and use .040 gasket for around 11:1
Old 12-16-2008, 03:15 PM
SOMbitch's Avatar
Any input?
I don't think you will SAFELY clear.
No mill, factory gasket 11+2 should put you .080ish on that cam I believe. That's as tight as would go.
Old 12-16-2008, 08:32 PM
Zach79Z's Avatar
Hmm..several people said i would be fine...Anyone else think i wont safely clear?
Old 12-16-2008, 08:54 PM
regency's Avatar
check PTV no matter what choice you make to do
Old 12-16-2008, 09:05 PM
VIPERBLUELX's Avatar
with his 241 heads?
Old 12-16-2008, 10:39 PM
SOMbitch's Avatar
Originally Posted by VIPERBLUELX
with his 241 heads?
That was about as big as I could fit without recessing valve in my setup.
Also search Chrs1313. He is stock headed with same duration 111LSA cam and originally set it up with 4* advance but after checking PTV backed the advance down to 2* to gain more clearance and keep it safe IIRC.
Maybe he will chime in here.....
EDIT: Here ya go
http://www.ls1tech.com/forums/genera...m-curious.html)
Old 12-18-2008, 04:41 PM
Zach79Z's Avatar
Gunna skip the milling
