Can I run Comp Cams XR265HR Camshaft with LS6 Valvesprings??? (XR265HR vs LS6 Cam)
I have a 99 vette that will run a vortech supercharger and I'm trying to make a decision between the LS6 or the XR265HR camshafts. Keep in mine that I'm not swapping the heads they will remain stock, it's just a cam swap it'll be doing. Is it worth the extra money to get something alittle better then the LS6? Also can I run 02-04 LS6 Valvesprings with the XR265HR camshaft?
XR265HR Cam Spec:
Cam Style: Hydraulic roller tappet
Basic Operating RPM Range: 1,500-6,800 RPM
Intake Duration at 050 inch Lift: 212
Exhaust Duration at 050 inch Lift: 218
Duration at 050 inch Lift: 212 int./218 exh.
Advertised Intake Duration: 265
Advertised Exhaust Duration: 271
Advertised Duration: 265 int./271 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.558 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.563 in.
Valve Lift with Factory Rocker Arm Ratio: 0.558 int./0.563 exh. lift
Lobe Separation (degrees): 115
LS6 Cam Specs:
Basic Operating RPM Range: 1,500-5,200
Intake Duration at 050 inch Lift: 204
Duration at 050 inch Lift: 204 int./218 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.550 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.550 in.
Valve Lift with Factory Rocker Arm Ratio: 0.550 int./0.550 exh. lift
Lobe Separation (degrees): 117
XR265HR Cam Spec:
LS6 Cam Specs:
