590 cam and stock rockers?
Old 12-15-2008, 06:31 PM
KingTA's Avatar
Default 590 cam and stock rockers?
recently bought a c5 with ported heads and cam, i cant remember the cam specs but it was a 590 something, anyway the car has a little valvetrain noise and still has stock rockers, should i replace them or what??
Old 12-15-2008, 07:50 PM
teke184's Avatar
all ls1s are noisy
many many guys run stock rockers up well past .600" lift
Old 12-16-2008, 12:07 AM
KingTA's Avatar
also what length pushrods should i have?
Old 12-16-2008, 12:09 AM
LSX Mechanic
Damian's Avatar
Noise from the valvetrain is normal with almost any aftermarket cam.
Pushrod is measure using the base circle of the cam and preload measurements. Thats kind of hard to tell you since you have zero knowledge about the cam in the car, nor has the base circle ever been measure.
Dyno the car. If there's no dips in the higher RPM's your valvetrain is probably fine. If it makes you feel any better, pull the valve covers off, loosen all the rockers, put #1 at TDC, and re torque them all via GM sequence.
Have fun
Old 12-16-2008, 12:57 AM
the_merv's Avatar
^^Is there a sequence? I always just put them on at 22ft/lbs no matter where the Engine was at, then rotated it and checked them all again.
I'm using stock Rockers, and my Cam is a .621/.612 Lift.
Old 12-16-2008, 01:14 AM
LSX Mechanic
Damian's Avatar
Yes there is a sequence. TQ'ing them straight down the line tends to put preload all over the place.
Do a search. The GM TQ sequence is all over the internet. I am too lazy to type it all out lol
Old 12-16-2008, 01:34 AM
smokinponcho73's Avatar
Ya I'm pretty sure my chiltons just said 22 on all of them
Old 12-16-2008, 02:01 AM
the_merv's Avatar
I'm sure it can be done with the Cylinders at TDC, and just rotating it in the Firing Order.
Old 12-18-2008, 08:34 PM
red83's Avatar
Location: sneaking in your back door as you leave!/cartersville ga
i had a .649 lift cam w/ stock rockers on my turbo car
Old 12-19-2008, 08:41 AM
Shawn MacAnanny's Avatar
I have stock rockers on a .651 cam no problems so far.
Old 12-19-2008, 08:43 AM
Sharpe's Avatar
.598 and 123,000 here.
Old 12-19-2008, 10:33 AM
cabech984's Avatar
From what I gather, the only major concern in using stock rockers is more valve guide wear than if a smaller cam was used.
Idk for sure though, Im gonna try it out lol.
