485hp slp package
Old 09-28-2003, 12:24 AM
LPCWS6's Avatar
Default 485hp slp package
I just wanted to know if anyone tried it yet and what you guys think of it. Here is a link if you have not seen it. slp 485hp package
Old 09-28-2003, 12:29 AM
9T9BlueTA's Avatar
Default Re: 485hp slp package
Doesnt SLP go by Flywheel numbers?
Old 09-28-2003, 12:33 AM
NataSS Inc's Avatar
yes they do. And I dont think I have ever seen an ALL SLP package make to much power.
Old 09-28-2003, 12:34 AM
LPCWS6's Avatar
yes I think those are flywheel numbers. I don't know what percent these cars lose through the drivetrain. I was told my last car lost 22 or 23%.
Old 09-28-2003, 12:43 AM
blk~2000~Z28's Avatar
Milled 63.5cc combustion chambers raise compression ratio to 10.7:
I am no expert but if you mill out a CC wouldn't that remove material effectively lowering compression. Milled heads maybe
I think that the cam alone would benefit any LS1 engine. The heads are CNC'ed so I would bet that any of the ----> sponsers CNC'ed heads would be "roughly" the same. With most CNC'ed heads out there I would be concerned with cost before their numbers, b/c there are limitations with CNC'ing. This could be why hand ported cost more, just my .02
Old 09-28-2003, 03:20 AM
1BadAzzWS6's Avatar
I was told for the M6 f-bodys we lose 16%.
Old 09-28-2003, 10:15 AM
B-MAN's Avatar
Did you notice that nothing was mentioned about rear wheel HP gains. The question is, is this flywheel of rear wheel power?
Old 09-28-2003, 10:50 AM
Krazy98Z28's Avatar
SLP numbers are always flywheel cause it makes it look like it puts out tons of power. Although with the camshaft they are using I dont doubt that package would put 400 to the rear wheels.
Marco
Quick Reply: 485hp slp package
