Will bent rocker cause tapping?
Will a bent rocker cause a loud tapping (and by loud, I mean a car with true duals next to me cannot hide it)... my mechanic believes thats the reason, so I figure if it is, I'll do a swap for a new set I found on Summit.
Also, is there any advantage to upgrading them? I might do H/C later, so...
It's coming from the driver side, or atleast, its louder over there. I might try this tomorrow.
See if you can get a 24mm wrench on it. Not familiar with the f-body as I have a Vette. In the Vette, the rack sits right in front of the pulley and you are limited to what you can get in there. Having the plugs out will help when its time to turn it. To find TDC, watch for the #1 intake to close and then bring the piston to the top.
