Checking for bent valves
Old 09-29-2003, 08:16 PM
BadAndy's Avatar
Default Checking for bent valves
Can you check for a bent valve without pulling the head? Thanks
Bad Andy
Old 09-29-2003, 09:03 PM
BergerMan's Avatar
Default Re: Checking for bent valves
Checking the compression on each cylinder using a compression tester will tell you very easily. I suspected a bent valve and checked each cylinder. #7 would only build up 110psi and the others were at 215. I knew right away. Obviously checking the springs first to be sure one is not broken is step #1.
