Which connecting rods for 6.0 build up?
Old 09-29-2003, 11:01 PM
Okie02's Avatar
Default Which connecting rods for 6.0 build up?
i have asked this before but i never have got some good clean answers...i already have my diamond pistons...its a 6.0 bored .030 over which makes it around a 370ci. motor.. im gonna run a pretty big shot of nos so im gettin the forged steel 4340 h-beam design but i dont know what brand to get...right now its a toss up between manley, eagle and lunati...help me decide!!! thanks!
Old 09-30-2003, 12:14 AM
Crunch's Avatar
Default Re: Which connecting rods for 6.0 build up?
I went with the Lunati Pro-Mods. They're good for well over 700 RWHP.
If you're going with a big shot later on (250+), I'd get the Pro-Billets. I believe your block will crack before those go.
I also went with Diamond Pistons (dished 9.1:1 CR).
Old 09-30-2003, 10:59 AM
Vents's Avatar
a vote for eagles. good rods IMO. and not all insane expensive. will handle 700+ easily ;D
Old 09-30-2003, 11:16 AM
humanoidZ06's Avatar
Another vote for Eagle. I've never had a problem with any of their products.
Old 09-30-2003, 12:03 PM
BIGBOS's Avatar
I vote Eagles as well....I used them on my 6.0L block .40" setup....
Old 09-30-2003, 12:06 PM
robertbartsch's Avatar
Can the Eagles be purchased in 6.125" length or only 6.1"?
Since he has ordered the pistons already, I assume he is locked into the 6.125" lenght rod...
...so is he stuck with Manley's or Lunati's?
Old 09-30-2003, 06:54 PM
Okie02's Avatar
i can still purchase the eagles...i think i found a better deal though on some manleys check it out....
CLICK HERE
do u guys think this is a good deal? im gonna be runnin about a 200 shot at the biggest...do u think these will hold?
Old 09-30-2003, 08:50 PM
Okie02's Avatar
ANYBODY??
Old 09-30-2003, 08:56 PM
Jammer's Avatar
I chose some Carillos... 80 percent of the teams competing in NASCAR Winston Cup, SCCA Trans Am and Pep Boys IRL use them.They are a chromium / nickel / vanadium / molybdenum FORGED alloy. The fasteners are the weak spot in many connecting rods... seems many beleive the Carillos use the top rated system.
Old 09-30-2003, 09:21 PM
Okie02's Avatar
CARILLOS ARE TO EXPENSIVE FOR ME
Old 09-30-2003, 09:28 PM
Jammer's Avatar
You can get them used for the 5-6 hundred range, some companies have shelves full of them from the race cars they need to sell. Just a thought. Search the net if your interested. I 'll post the link if i can find it again. I know, I know...why used carillo in place of new eagle. I dont have an answer..thats just a personal preferance thing.
Old 09-30-2003, 09:34 PM
Okie02's Avatar
thanks for the help, but im probaly gonna go either manley or eagle rods...i cant decide...the only reason im considering manley cause the 03 cobra has manley rods...and its 3X stronger than a camaro or vette motor...
Old 09-30-2003, 10:34 PM
Okie02's Avatar
well where is a good place to purchase eagle rods?
Old 09-30-2003, 11:43 PM
Jammer's Avatar
Speed Inc. Call them for current pricing. Web has them at 599..but call 1st.
Old 10-01-2003, 02:31 AM
NX†C's Avatar
I would recommend Lunati Pro-Mod to Pro-Billet depending on how big of a shot you want to run. As already said Lunati Pro-Mod will handle 700RWhp, and anything over that look to the billet. Eagle rods are a good quality rod but they are the first one to bend out of all the rods that I have seen in past experiences. The other recommendation is that although unfortunately you said that you already own the pistons, to get a set of JE pistons if you are going to run a large shot of n20, Diamonds are great pistons, don't get me wrong on that part, but just that JE is the better for n20.
Old 10-02-2003, 08:39 AM
Try the Crower sportsman rods for $435...
SDPC sell em ---------------->
http://www.sdpc2000.com/cart.asp?act...amp;pid=153424
Old 10-02-2003, 08:59 AM
Heretic's Avatar
The factory rods are 6.098" and most LS1 aftermarket rods are 6.1, 6.125 and 6.2"
Are the 6.1s considered to be stock length?, what about the 2 thousanths? Or do they just round it up?
Old 10-02-2003, 09:00 AM
Super Moderator
Reckless's Avatar
I am using Eagles in mine with a stock bore. $599 is high for Eagles. Try calling Chris G. at Diamond. He can sell them to you also.
