PP 2029 heads + TSP 228R ok?
Just want to verify these heads:
https://www.patriot-performance.com/...&cat=37&page=1
Will work fine with a TSP 228R cam on my stock 01 Z06.
Thanks!
Kevin
Thanks!
Kevin
LS1Tech Premium Sponsor
That depends a lot on the brand valve, milling, etc. to determine if this combo will work. My gut is it probably does, but you always want to check when mixing & matching parts that aren't typically put together. We run the PRC stage 2.5 & stage 1 LS6 heads with custom milling for this camshaft all the time. With a properly setup cylinder head you should be able to get some milling & maybe a thinner gasket with the 228R camshaft.
Research the dyno section before making your final decision, we've made over 440rwhp with a ls6 intake & the Precision Race Components head & 228R camshaft.
http://www.texas-speed.com/shop/item...d=649&catid=20
stage 2.5:
http://www.texas-speed.com/shop/item...d=133&catid=40
stage 2.5:
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
All I know is they are the 2029 heads which were freshened up with new valves etc and are 58cc. Here is the ad:
https://ls1tech.com/forums/lsx-parts...reshen-up.html
