4.30s gears
Old 12-29-2008, 01:50 AM
sspower23's Avatar
Default 4.30s gears
Hey guys Im probably sure someone might have already asked this one before but I was wondering if putting 4.30s or 4.56 gears in a stock ls1 camaro ss, would be an ok idea or not? If yes, what should I know about all this and any precautions I should take? Later Im thinking of installing a Trex cam
Old 12-29-2008, 01:55 AM
WSsick's Avatar
wrong forum bud. try GEARS & AXLES down a little farther. if you think someone has asked it (which they in 7 years, someone has) then search it. dont eat up space with questions that have answers.
Old 12-29-2008, 06:04 PM
eamador11's Avatar
Thats too much gear unless your car wil be full time drag car trying to get every ounce of ET possible. 4.10s is plenty for the street NA car.
Old 12-29-2008, 06:05 PM
eamador11's Avatar
bro your still a newbie to say such things
Old 12-30-2008, 12:59 AM
JPH
JPH's Avatar
Put a 28" tire underneath it, killer trq arm, lca relocates, shocks and let it hit.
Old 12-30-2008, 01:04 AM
1sicws6's Avatar
Lies, I have 4:30's in my daily driven street car thats stock and love it!
Old 12-30-2008, 01:17 AM
PREDATOR-Z's Avatar
Not in a stock rear. 4.11 is allready making a fragile rear more so (especialy M6). IMO save $$ for a 12 bolt or 9" first.
Yes a T-Rex would like tighter gears to get in the band quicker.
Old 12-30-2008, 01:44 AM
SS4Luck's Avatar
i went 411s and regret not going 430s. put a big cam and 28" tires on it and youll be plenty happy
Old 12-30-2008, 07:20 AM
Hardtop's Avatar
I ran 4.30's with a 27" tire, and 4.57' with a 28" tire on my 2001 H/C Z/28. 4.10's are good gears for a bolt on street car. As other have mentioned, the stock rear won't hold up long with a big gear and traction.
Old 12-30-2008, 07:50 AM
greatskiiiier's Avatar
dont put them in a 10 bolt, and you dont want anything higher then 4.11s until you have a decent size cam anyways.. the point of gears is to get you to the powerband you want and stay there as long as you can, something that high on a stock ls1 cam will give you no time at peak HP before itll be hitting the limiter... i say 3.73s are the highest you want in a 10 bolt as well
Old 12-30-2008, 08:27 AM
Randy WS6's Avatar
4:30's here ,love um, with 335/35/17's
Old 12-30-2008, 11:05 AM
01ssreda4's Avatar
4.30s are fine for a manual car with an aftermarket rear.
Old 12-30-2008, 01:32 PM
purdueranger's Avatar
Old 12-30-2008, 01:41 PM
TJ
TJ's Avatar
i jumped from a 3.70 to a 4.30 and only picked up .07 hundreths. im not going back, but i miss my cruising speed.
you really need to make a bigger jump for a large impact.
if its weekend car, strip only, 4.56.
if its a stock 10 bolt and you drive it, id get tired of the 4.56.... IMO
Old 12-30-2008, 03:25 PM
studderin's Avatar
I really like my 4.30s, had 3.73s beore. And I street drove on stock whells only 25.8 tall.
I would have gone right to 4.56s with 28" slicks but you run out of gear at 130's taking your motor to 7K.
Old 12-30-2008, 03:33 PM
silverLSWON's Avatar
i run 4.56's in my 12 bolt and got 29.6 mpg on the highway driving to memphis. i run on a 27' tire and it's tight going through the traps with my H/C.
Old 12-30-2008, 03:42 PM
WSsick's Avatar
hey BRO, im sorry i dont have the vast time here or number of posts here you do.screw off or add something to the question
Quick Reply: 4.30s gears
