Hard Black deposits in my oil? What are they?
As said above, the last few oil changes I have had small black deposits in my oil. It doesn't appear to be metal shavings. You can take the small deposits and scrub them between your fingers and it will break up. Does anyone know what this might be? Is it bad? My oil has also reaked of gasoline the past few changes too. What do you guys think?
Might be carbon build up thats passed through the filter. And if your smelling gas in your oil it could be a few things. Rings, emission systems, pvc, off the top of my head thats all I can think of. Im sure someone else will chime in and give you a more solid reason.
Sounds like carbon build up. Pop a valve cover & see if the rockers & valve stems are covered in the same deposits. If so, an AutoRX treatment will SAFELY get rid of it. AutoRx can be found on line.
You might have a hole in a piston or a broken or bent valve. How else can carbon get from the combustion chamber into the crankcase? This would also explain the gasoline in your oil. Check your plugs.
