CR on lq9 ?
Old 12-31-2008, 12:32 AM
pewter02z28gs's Avatar
Default CR on lq9 ?
does anyone know what the cr is on a totally stock lq9 with stock 241 heads on it?
Old 12-31-2008, 03:06 AM
405HP_Z06's Avatar
Old 12-31-2008, 02:33 PM
10.70 lower then i thought
Old 12-31-2008, 03:48 PM
STOCK12SECZ's Avatar
Originally Posted by 405HP_Z06
Not to steal this thread. Since you have a nice calculator.. How about a
LQ4 with 59cc heads. Think the dish in a LQ4 piston is -6cc. Stock gasket.
Thanks
Old 12-31-2008, 03:55 PM
GMCtrk's Avatar
How about an LQ9 with stock gasket and 243 heads?
Old 12-31-2008, 04:19 PM
WYATT318MOPAR's Avatar
here is everyone a calculator..
http://web.tampabay.rr.com/1bking/ch....htm#calc_comp
Old 12-31-2008, 05:28 PM
405HP_Z06's Avatar
Originally Posted by WYATT318MOPAR
This calculator, like most, doesn't account for piston top OD and ring depth. It also makes an assumption on head gasket bore diameter that's incorrect. Close but no cigar.
Old 12-31-2008, 05:42 PM
zx9rgreen's Avatar
This calculator, like most, doesn't account for piston top OD and ring depth. Close but no cigar.
So where is your calculator
Old 12-31-2008, 05:43 PM
405HP_Z06's Avatar
Thanks
Old 12-31-2008, 05:44 PM
405HP_Z06's Avatar
Old 12-31-2008, 05:46 PM
405HP_Z06's Avatar
On my computer, you can purchase the program from Performance Trends. It's called Compression Ratio Calculator.
Old 12-31-2008, 06:31 PM
now the question is that bump in cr worth more then like 5 horsepower
Old 12-31-2008, 06:46 PM
djsanchez2's Avatar
I got 10.9:1 for the LQ9 guy on the free calculator, but i guess that little bit can make the difference on a built race motor.
Old 12-31-2008, 07:36 PM
405HP_Z06's Avatar
If accuracy isn't a concern than why even calculate it? There is only one correct way to calculate compression ratio and as long as the parameters are correct one can't argue with the math.
Old 12-31-2008, 08:29 PM
Much appreciated!
Old 12-31-2008, 11:08 PM
405HP_Z06's Avatar
If your going to swap heads, at least use some 243's.
Old 12-31-2008, 11:19 PM
GMCtrk's Avatar
so it looks like I'll be sitting at right at 11:1. That should give me a nice gain coming from 10.1:1
Old 12-31-2008, 11:30 PM
the_merv's Avatar
Stock 241's on a LQ9 is going to suck ballz..
Old 01-01-2009, 12:03 AM
GMCtrk's Avatar
Yep.
I'm personally debating picking up some 241s dirt cheap and having them ported. 11:1 may be too much compression for me. The 67cc 241s would be more friendly
Old 01-01-2009, 12:19 AM
the_merv's Avatar
Go with L92's..
Quick Reply: CR on lq9 ?
