Cant wait to see what Advanced Induction has in store for me
I just sent them my heads off my car and they are putting me together my heads/cam combo for my car! Cant wait to see the number with their camshaft and their awesome heads! One of my buddies made 430rwhp with their stock ported 241's and stock camshaft!
Was that on Wiggins' dyno?
They. Haven't given me my cam specs yet I told them mid 230 duration with around 600 lift ill be sure to post on my dyno results and track times when I get everything in and tuned by Alvin at pcm4less!
ya this is some funny **** right here!! hey man those guys just tuned my stock 96 saturn with ported heads stock cams it made 360rwhp!!! bullshit dyno rigged up to make the customers happy hahaha. i want to see that same car dyno at a real LEGIT shop, i KNOW it wont make anywhere near those numbers on a different dyno.
I would assume the latter half of your post is either said in jest or you haven't been paying attention for the past 5 years. Many of the fastest LT cars run either our heads & valvetrain or an engine we built. If there is anyone else consistently able to deliver 500-600rwhp NA from a pump fuel LT1 we would like to know about them
Recent Example: https://ls1tech.com/forums/lt1-lt4-m...na-9s-n2o.html
Here is the graph showing the difference between what it made with full bolt ons (~360rwhp), the addition of cutting his stock 241's & 1.85rr's, then going speed density, and finally dropping the belt for a pull. A gain of ~47hp peak does not seem unreasonable for heads/rockers & CR in the low 11's.
http://www.advancedinduction.com/Dyn...kCamCNC241.jpg
Are Russ' numbers repeatable? Of course. Common? Obviously not, most customers go with a camshaft first. That being the case, there is a lack of stock cam results for any one to make a valid comparison in our opinion. Most guys with a cut 241 head at 11:1 with a 227-232deg HR that is mild enough to be controllable to beyond 7000 will be in the 425-445rwhp sae range. Add a TB, FAST, etc. and the numbers typically shift upwards into the 440-470rwhp range. Obviously there is a host of variables that need to be addressed to reach the high side of the spectrum.
Thanks for the interest, guys.
DID YOU REALLY JUST SAY THAT U CAN MAKE 440-470RWHP WITH THE STOCK CAM?!?!?!?!?!
COUGH BULLSHIT COUGH.......
ya that was me who sent the heads to be ported and custom grinded camshaft
He said with a cam!
my setup will be ported 241's ai
custom grind camshaft from ai
ported fast 90 with nw 90mm throttle body
through longtubes and true duals along with all the other boltons
along with arp bolts new rings and etc im expecting to make alot of horsepower cause AI can prove their numbers! Then im gonna hit it up 150 shot expecting to make over 600rwhp im hoping for 470-480 on motor
He said with a cam!
