vindicator cam, and clearance....
Old 01-01-2009, 05:27 PM
Jonsz28's Avatar
Default vindicator cam, and clearance....
as from my understandings, the vindicator would be a fantastic choice for the daily driver in a ls1, and i also understand that you can run the prc stage 1 heads without n e problems, but someone told me that the cam was so big that there wasnt enuff clearence to be safe, he said that if the car was at a high rev and you went to shift from second to 3rd and ur rpms hadent dropped and u just so happened to miss the gear and get back on ur rpms, that ur subject to espacially bend a rod.... but im just not very famialiar with this big of a cam so if u could give me some info, so i could go ahead with the install or consider something else... thanks
Old 01-01-2009, 05:49 PM
Zach79Z's Avatar
A buddy of mine has the vindicator in his trans am and daily drives it and from what i hear fits perfrectly fine with stock heads but im not sure about other heads. Id pm ron @ vengeance about the clearnace cause im sure he knows
Old 01-01-2009, 05:52 PM
robbinthehood's Avatar
Yeah, just contact ron he'd clear it up for you easily.
Old 01-01-2009, 07:31 PM
98blueSScamaro's Avatar
this cam will fit fine with the prc stage 1 ls6 heads as long as you dont get the heads fly cut at all. ls6 heads have more room then stock heads
Old 01-01-2009, 07:33 PM
Super Speed's Avatar
I'm pretty sure you have to check your PTV with this cam
Old 01-01-2009, 07:38 PM
405HP_Z06's Avatar
Agree^^^^^^^^ ALWAYS check PTV clearance.
Old 01-01-2009, 08:58 PM
tillery's Avatar
YEP check PTV because of any slight differences. from block to block. Also at the same time get it degreed.
Old 01-02-2009, 12:52 AM
PREDATOR-Z's Avatar
Yes it will fit with those heads if not milled. (flycut is for pistons) and no LS6 do not have more room than LS1 heads.
That cam is 240/244 IIRC so yes any cam over 230* it is always wise to degree ity and check PTVC>
Quick Reply: vindicator cam, and clearance....
