looking to get 450 to 500rwhp street car
i have a all stock 2001 blk camaro ss.
i am looking to get it up to 450 to 500 rwhp
can you guys give me a setup that can reach that also i am looking to go with texas speed ms3 cam any other cams in mind let me know thanks
The "recipe" to 500 rwhp with heads and cam
Suggested reading. Patrick gives all the details, what you lose if you cut a few corners, etc. It's not cheap to get there, but it's certainly possible IF you adhere to the "recipe".
Also, if streetability is a huge concern, more displacement makes it much easier to get there. Whether through additional cubic inches or forced induction, it takes air to make horsepower.
there is a considerable difference when trying for 450rwhp and trying for 500rwhp.
450 is attainable with a decent cam, good heads and bolt ons.
500 needs everything in the book and some specially designed parts to maximize the setup.
unless you go FI or stroker.
icic i dont want to go that far then with the 500 i say hit 450 rwhp at the most ive done some research and it take a lot to get 500 rwhp so 450 it my goal to reach
have any option?? i purchased the ms3 cam and am noticing the custom grind gives alot would that have been a better option
ms3 is a good start.
now get the best heads you can afford, get compression up (possibly flycut) and put a ported FAST on it.
a good dyno tune and you should be there.
what's the rest of your driveline like? things like stock clutch and rear end won't hold up long to 450rwhp.
umm yes m6 all stcok
the first things that i will be doing will be
ms3 cam. headers.exhuast. TB. LId..
clutch ?? when i get on it hard my clutch doesnt release it sticks to the floor..
its a brand new clutch from GM.. could it be the wrong clutch or is this regular
The MS3 is a great start, any longtube headers will do you justice. american race headers (ARH) would be my vote but they are quite pricey. As far as exhaust i'd look at going at a full 3" true dual setup, give you the most hp possible. I believe texas speed makes a true dual setup.
I'm no car or f-body guru but if you have any questions feel free to send me a PM. Sponsors will be your best friend on here and are very helpful!!
