Torquer V2 Install...is an Adjustable Timing Chian Set necessary?
It isn't necessary unless you want to degree the cam yourself as opposed to installing it dot to dot, I believe this is correct. Did TSP say you were ok with PTV clearances with that setup?
it will be close, it did help me out having a adjustable one.
I would sell the ls2 and have some peace of mind. It would suck to get in and find out you need one with your car torn down.
