MTI G1 Cam specs
Old 01-03-2009, 09:09 PM
vettett15's Avatar
Default MTI G1 Cam specs
Hey Guys,
I was wondering if anyone had a cam card for their MTI G1 cam or knew the specs by chance. I have one but I am not sure if the numbers or right or not.
Old 01-03-2009, 09:21 PM
10 Second Fun Car
jlrz28's Avatar
Intake duration @ .050: 228
Exhaust duration @ .050: 232
Intake lift .588
exhaust lift .575
LSA; 113*
Old 01-03-2009, 09:22 PM
vettett15's Avatar
that would be correct
Old 01-04-2009, 01:02 PM
vettett15's Avatar
I was hoping for some valve events @ .050" if anyone has them....
Old 01-04-2009, 01:04 PM
Gregorya24's Avatar
great cam, i got a messed up one sitting in my room from a lifter lol
Old 01-04-2009, 04:53 PM
10 Second Fun Car
jlrz28's Avatar
Serial # G 2971-05 Spec Card# 08904205
Part # 54-000-11 LS1 CHEVY LS1/GEN III '97-UP ROLLER
Core C54-11A LS1 1997 UP 5.7 CORVETTE 5150 SEMI
Grind # LS1 3633R /3634R HR113+4
DURATION @ .050 INTAKE 228 ROCKER ARM RATIO
VALVE ADJ INTAKE .000 DURATION @ .050 EXHAUST 232 INTAKE 1.70
VALVE ADJ EXHAUST .000 LOBE LIFT INTAKE .3530 EXHAUST 1.70
VALVE LIFT INTAKE .600 LOBE LIFT EXHAUST .3540
VALVE LIFT EXHAUST .601 LOBE SEPARATION 113.0
DURATION .006 INTAKE C/L 109.0
TAPPET LIFT INTAKE 278 CAM ADVANCE 4
TAPPET LIFT EXHAUST 281 HYDRAULIC Y
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 5 JOURNAL DIAMETER STD 2.165
VALVE OPEN EXHAUST 53 RECOMMENDED VALVE SPRINGS
VALVE CLOSED INTAKE 43 DEPARTMENT P
VALVE CLOSED EXHAUST 1- SPC INSTR FOR CUSTOMER
Quick Reply: MTI G1 Cam specs
