LPE releases Darton wet sleeve LS1/LS6 block conversions
Old 10-01-2003, 10:22 AM
Closed ex-Sponsor Account
Ed Potter @ LPE's Avatar
Default LPE releases Darton wet sleeve LS1/LS6 block conversions
We have finally perfected the machining process required to install the Darton modular wet sleeve sets into production LS1 or LS6 blocks.
This has been an ongoing project for quite some time, but we have finally resolved all of the leaking, and cooling issues, and are so confident in these sleeves that we are also offering an installed package using this block.
We can do the conversion on your block, or supply you with a core block if you like.
Please let me know if I can answer any questions for you,
Ed
Old 10-01-2003, 10:28 AM
robertbartsch's Avatar
Default Re: LPE releases Darton wet sleeve LS1/LS6 block conversions
Great news!
The pricing for the sleeves and machining is listed on your web page which is informative.
You don;t indicate the estimated price of a core block if a customer wishes to buy the core from you, however....
Old 10-01-2003, 10:32 AM
Sorry....your web page does say the core is $600 which is competitive with other vendors...
Thanks...
Old 10-01-2003, 10:53 AM
ED:
There has been a lot of debate here about which system, (dry or wet sleeve)is better. Obviously, you choose the wet sleeve system for good reasons.
Can you tell us why?
Are there any special considerations; do you need special head gaskets, head bolts, or other things to assemble the engine...some have suggested that this system is prone to lift heads under extreme loads; can you comment on this?
Thanks...
Old 10-01-2003, 10:58 AM
NA$TY-TA's Avatar
Any Links?? Couldnt find it.
Old 10-01-2003, 11:16 AM
93Polo's Avatar
http://www.lingenfelter.com/lingenfe...mp;pf%5Fid=534
Quick Reply: LPE releases Darton wet sleeve LS1/LS6 block conversions
