Any good write ups on Roll Master Double Roller Timing Chain
Old 10-01-2003, 08:08 PM
frcefed98's Avatar
Default Any good write ups on Roll Master Double Roller Timing Chain
I just want to make sure I get this thing in the right way.
I noticed two dots on the crank gear. Which dot do I use if I was going dot to dot with the cam gear(straight up?) The one on the chain gear face or the one on the crank snout(?) area. I guess you can call them lower dot or upper dot.
Thanks,
Jeremy
Old 10-01-2003, 08:43 PM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
Default Re: Any good write ups on Roll Master Double Roller Timing Chain
Line the dot next to the keyway (inner dot) to the crankshaft keyway. The timing chain dot (outer dot) is the dot you use to line up the camshaft gear and crank gear with. Thats if your setting it straight up on the gear.
Old 10-01-2003, 08:49 PM
frcefed98's Avatar
Thanks Joseph, I woulda f@#Ked that up big time.
J
