LS2 Timing Chain Dampener Modified & Installed on LS1 Block
Old 01-14-2009, 01:32 PM
rikhek's Avatar
Default LS2 Timing Chain Dampener Modified & Installed on LS1 Block
A broken LS2 timing chain on my LS1 mild head/cam engine prompted me to install a timing chain dampener. I also put in a Katech C5-R timing chain manufactured by JWIS.
As many know the "beige" LS1 dampeners with ~2.1" bolt hole centers are no longer available. The "black" LS2 dampeners with ~1.7" centers are available. Problem is the bolt hole centers on the "black" dampeners don't match the bosses on the LS1 block.
The solution we came up with was to modify a "black" dampener. We milled out a little of the inner webbing on a "black" dampener and fabricated two 0.125" aluminum inserts and bushings. Measured proper bolt hole spacing and drilled the inserts.
Also had to drill and tap my block to install. Some early LS1 blocks came from the factory drilled. Mine did not.
Probably would have been easier to buy a chunk of nylon and trace out a pattern using a "black" dampener, however, we were unsure of the type of nylon to use which would stand up to the application....
Photos are provided below. I don't have a photo of an unmodified "black" dampener but a link to one is provided.
On a closing note, damage to my engine was limited to the heads. Had to replace all valves and have them milled. Lot of labor and money....
http://www.crateenginedepot.com/stor...P2276C119.aspx
Rick
Old 01-14-2009, 05:50 PM
drain89's Avatar
Why not drill and tap the block for the 1.7" spacing? The link you posted says you can. Is it wrong?
Old 01-14-2009, 10:30 PM
rikhek's Avatar
The link is WRONG. Block has raised bosses which get drilled for the bolts. No way to drill for the 1.7" holes of the LS2 dampener and get it to mount flush. Thickness of block off the bosses is also an issue.
Old 01-14-2009, 11:04 PM
5.3LJimmy's Avatar
Are the center punch marks in the picture marking where the 1.7" spacing would fall?
Old 01-15-2009, 05:34 PM
rikhek's Avatar
Yes. Wanted to see exactly where they'd fall....
Old 01-15-2009, 05:36 PM
RyderTA's Avatar
Looks like you did a pretty good job on that, hopefully it works good.
Old 01-06-2012, 09:30 PM
unclebens's Avatar
how many people are breaking ls2 timing chains?
Old 01-06-2012, 10:45 PM
wildcamaro's Avatar
I got 3000 miles on mine with 243s and a 224/230 cam no problems here
Old 01-06-2012, 11:12 PM
01ssreda4's Avatar
Not many, it seems to be relating to some aftermarket balancers, M6 cars, and road racing. That's where most of the failures are coming from.
Old 02-16-2012, 06:00 PM
TJTALS1's Avatar
I have one of the 2001 T/A's that came with the ls6 block. i wander if the wholes are predrilled in it?
Old 02-17-2012, 06:53 AM
vettenuts's Avatar
My 02 LS6 block in my 02 Vette (not a Z06) had the block drilled.
Old 02-17-2012, 07:07 AM
TJTALS1's Avatar
I hate tearing down a DD and finding surprises...
Old 02-17-2012, 06:17 PM
thepitstop2010's Avatar
My 02 LS6 block has the bosses tapped from the factory. I ordered a GM dampener from Katech. They have some of the factory dampeners still in stock. Your dampener style looks great and im sure I will have to do the same on my next build. Keep us posted on how it works out.
Quick Reply: LS2 Timing Chain Dampener Modified & Installed on LS1 Block
