how many degrees is one tooth on the cam sprocket?
Old 10-04-2003, 04:17 PM
1dirtyZ's Avatar
Default how many degrees is one tooth on the cam sprocket?
if i want to advance the cam , how many degrees is each tooth on the cam sprocket?
Old 10-04-2003, 04:30 PM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
Default Re: how many degrees is one tooth on the cam sprocket?
Each crankshaft tooth is 16.36 degrees, so each tooth off on the camshaft gear would be about 8 crankshaft degrees.
You need an adj. timing chain and a degree wheel to be able to adj. cam timing the right way though.
Old 10-04-2003, 04:32 PM
-Joseph-'s Avatar
Thats kinda weird, you have the same post count as I just did!
Old 10-04-2003, 05:33 PM
Tin Indian's Avatar
One full tooth off, and it will barely run, if at all
Old 10-05-2003, 12:05 AM
1dirtyZ's Avatar
just trying to see if i can take the easy way out, i just finished putting it back together after i advanced the cam 4 deg ( i do have a cloys adj. double chain).
i was having trouble pulling the cranck sprocket but i found a friend who lent me a tool to pull it out.
i started the car just to see if it even runs ( i was thinking i would have to do a cam position relearn deal or maybe even have the pistons smack the valves ( my kind of luck) but it fired right up, but it had a clacking noise that went away right away. i'm thinking it's just the adj. rockers loose while the lifters where pumping up.
we'll see how it runs in a few hours.
Quick Reply: how many degrees is one tooth on the cam sprocket?
