bearings coming out my azz!!
Old 10-10-2003, 03:40 PM
White Fire'99's Avatar
Default bearings coming out my azz!!
decided to change my oil since the car is 3 feet off of the ground for a header install. low and behold needle bearings like a cheap get well thing in the hospital on my drain plug . so of course i open up the passenger side to find.......nothing and then go to the drivers and there the little biatch is. exhaust rocker on cyl. 5 all bearings are gone from one side and i don't see the cover either, yet.
car only has bolt-ons and has just over 18,000 miles on it. only hit the rev limiter a couple of times too.
Old 10-10-2003, 04:07 PM
Moderator
John B's Avatar
Default Re: bearings coming out my azz!!
Welome to the broken roller rocker club!
Old 10-10-2003, 04:38 PM
Colonel's Avatar
You might need to see a doctor about that!
Old 10-10-2003, 04:55 PM
eallanboggs's Avatar
Jesel shaft mounts or Comp Pro Mags. You must be wearing a horseshoe around your neck to be able to avoid major damage with that rocker flopping all over the place.
Old 10-10-2003, 04:57 PM
jmX
jmX's Avatar
I dunno, I've seen 3 local cars break rocker arms and they drove on it for weeks like that. All 3 are just fine, and we replaced the rocker and they went on their merry way. I don't think it's generally a very catastrophic situation on these cars, although I'm sure there's some exceptions to that.
Old 10-10-2003, 07:19 PM
*update*
i have found the cap and all but one bearing. so who knows where that little devil is.
i p/u a new rocker and it is installed.
now back to what i was doing before i was so rudely interrupted!
