what needs to be done to go from a 346ci - 382 ?
Old 10-13-2003, 11:53 AM
BLKWS6's Avatar
Default what needs to be done to go from a 346ci - 382 ?
Just curious, i was thinking about stepping things up a notch. The 382ci should be able to be done with the stock sleeves, right?
someone fill me in.
Old 10-13-2003, 12:03 PM
PacerX's Avatar
Default Re: what needs to be done to go from a 346ci - 382 ?
A 382 can be done via stroking, then you don't need sleeves.
But, if you do it via bore, you have to get sleeves.
Old 10-13-2003, 01:12 PM
Excal's Avatar
it seems they are both really expensive, specially longblocks.
Old 10-13-2003, 01:59 PM
BLKWS6's Avatar
to stroke it, besides the new crank, what else would you need to change? i assume you could keep the stock size pistons but how much longer would the rods have to be? if any.
Ive wondered about how this was done too.
Old 10-13-2003, 09:52 PM
kevredz's Avatar
Stock rods are 6.098" and stroker rods are 6.125" with a 4.000" stroke
