just got ls6 intake what to do along with installation
Is there anything I should do along with installation? I got the coolant bypass pipes. So I'm set for that aspect. Just wondering if there is something I should take a look at or change while the manifold is out.
thats about it, just follow the intrustions on installuniversity.com or ls1howto.com
make sure the seals are ok and tighen them in the correct order w/ the correct inch lbs
-brandon
-brandon
^^^^^x2 I broke that damn sensor when pulling my intake. The big brake booster line is more than likely routed behind it, and you'll snap it faster than **** if you're not careful.
Go ahead and replace the oil sender unit while the intake is out. The plastic on the OEM one gets brittle after so many heat cycles and you don't want to pull the intake again to re-do it. Make sure to buy/borrow the socket specifically for removing/installing the sender.
