Need an opinion a good one on Bent valves
Old 02-28-2009, 03:15 PM
SScamaro4's Avatar
Thumbs up Need an opinion a good one on Bent valves
I have 100psi on num 2 4 an 6 clyinder could i ever possibly bend that many valves at once or is that a sign of a blown head gasket i have a **** load of misfires
Old 02-28-2009, 03:48 PM
9000th01ss's Avatar
Thats not a head gasket problem.
Quite common to bend every valve in an engine if not properly set up.
Old 02-28-2009, 04:39 PM
XtraCajunSS's Avatar
Easy problem to diagnose if you have access to compressed air. You can remove the schrader valve from your compression tester and connect it to the cylinder(s) in question.
If you have air leaking into the intake, its a bent intake valve.
Exhaust header, its exhaust.
Excessive air into the crankcase, most likely a piston or ring issue, possibly head gasket.
If you pressurize the cooling system, cracked head or blown head gasket.
Shane
Old 02-28-2009, 05:51 PM
TroyBoone's Avatar
did this just happen all of the sudden? or did this start to happen little by little until you got to where you are now? also, did you squirt in some oil and re-check?
Old 02-28-2009, 09:42 PM
Greg Fell's Avatar
Shane
listen to this man, he speaks the truth
Old 03-01-2009, 09:22 AM
kharmichead's Avatar
Yes, you can bend that many valves at once...or more. Especially if the valves floated at high rpm. But if you have 100psi with your compression checker I doubt you would have that much with bent valves, usually it won't hardly hold any pressure.
Do what Shane's telling you, that's a 'poor mans' [no offense Shane] leak down tester. You won't get a leak down percent to know how bad they are but you will hear where it's coming from.
Are you 100% sure the piston is at TDC and doesn't move when you hit it with the air? Sometimes the motor can roll over a bit when you hit it with air and open a valve just enough to cause a 'leak'.
Old 03-01-2009, 09:30 AM
TJ
TJ's Avatar
moreso on a high milage or a loose motor. any movement of the piston is going to affect the position of the valve.
Old 03-01-2009, 10:52 AM
I forgot to mention something I thought would be obvious...
Remove the rockers from the cylinder you are testing to prevent the cam from opening the valves during the test...
Shane
Old 03-01-2009, 11:55 AM
TJ
TJ's Avatar
Shane
thats correct.
some guys dont want to undo the coils and valve covers.
if you hold the motor at TDC, you can get by with everything on.
more simple when its bare, though.
Quick Reply: Need an opinion a good one on Bent valves
