6.0 oil pan question
Old 02-28-2009, 07:07 PM
Vette454's Avatar
Default 6.0 oil pan question
I did a quick search with no luck , I have a lq4 engine and it came with the oil cooler lines on the oil pan , Im not using the oil cooler setup so can I just get the block-off plate and close up the holes without starving the engine for oil? Thanks for any help!
Old 02-28-2009, 08:59 PM
S10xGN's Avatar
I'd say, NO! On non-coolered engines, the oil passes through a small bolt-on adapter. In one port, through the adapter, out the other port. You'll get no flow with it blocked.
Russ
Old 02-28-2009, 11:03 PM
f-bodyguy's Avatar
im pretty sure you cant use the truck pan on an f-body
Old 02-28-2009, 11:17 PM
gold98Z28's Avatar
from the looks of his sig id say its not going in an fbody......
if it needs to flow(im not for sure, id have to look) then you could cut the lines and hook them together rather than running them all the way up and back.
Old 03-01-2009, 05:05 AM
Chris10an's Avatar
Exclamation
This is all wrong. You can plug that hole with a special adapter plate that you can order on your local GM spare parts dealer for truck with no oil cooling lines. We have done this many times when converting truck engines over to custom cars.
Old 03-01-2009, 05:00 PM
gold98Z28's Avatar
whats all wrong
Old 03-01-2009, 07:24 PM
S10xGN's Avatar
I wouldn't think this "adapter plate" actually plugs anything. The "car" style adapter is a pass-through. Think of it as a "U", oil goes in one end of the "U" and out the other. If either end were plugged...
Russ
Old 02-26-2010, 11:44 AM
8budchevy's Avatar
Default Lq4 oil pan in F-body
Is that right and LQ4 oil pan won't fit in an F-body?
Old 02-26-2010, 12:17 PM
408z28's Avatar
Russ
It doesn't matter if its plugged...you just don't have a oil cooler. Some trucks don't have them anyways. It doesn't affect anything inside the engine either way.
a LQ4/9 truck pan will "fit" any Ls style engine block....Its crossmember and ground clearance issues that make them not work for a different application..
To the OP...use the plate...you will be fine.
Old 02-26-2010, 04:28 PM
8budchevy's Avatar
I just went out and look at the LQ4 oil pan is have for my 408 install I am planning. See the photo attached. I believe I see where the plate you mention would go. Just like the AIR or ERG block off plate would look. This makes sense.
So my bigger question is will I have any ground/crossmember clearance issues with my build using the LQ4 oil pan on my 98 fbody? Stock height nothing special with the suspension.
Old 02-27-2010, 12:22 AM
408z28's Avatar
It will clear the crossmember... but it will sit about 1 inch from the ground. One good pot hole and its done. Use your 98' f-body pan....thats the only way to go.
Old 02-27-2010, 06:52 AM
8budchevy's Avatar
The potholes in CNY will eat that LQ4 oil pan up. Thanks for the info.
Old 02-27-2010, 07:14 AM
408z28's Avatar
Oh yeah! I was stationed at Ft. Drum (Watertown, N.y.) for a year. Roads up there were rough.
Old 09-07-2010, 04:32 PM
victor111262's Avatar
the oil pan would work fine it sits about 3 inches of the ground plus come on just be careful with the potholes i live in okc and the streets are a b@#$% but my oil pan is still ok,,,,,,but yea my next thing is an fbody pan i couldn't use mine cos blew a hole through it
Old 09-08-2010, 11:18 AM
EricD's Avatar
My 4.8 does not have an oil cooler, it is caped by gm with a block type plate so you can pick up that piece at a gm dealer and it will fit on the lq4 and you can even tap it for oil temp , the ls1 were taped for oil temp , Eric
Old 10-20-2010, 09:35 PM
KB1LQ4's Avatar
. . . a special adapter plate that you can order on your local GM spare parts dealer . . .
Does anyone have the GM part number for the LQ4 oil line block-off plate?
Old 11-03-2010, 01:28 AM
chuckd71's Avatar
gasket 12553210
Does anybody know the part no. for the one with the outlet already in it? Would save me the trouble of drill/ tapping for an oil pressure gauge.
Old 11-03-2010, 01:54 PM
Jim_PA's Avatar
Originally Posted by chuckd71
12577903
gasket 12553210
This one is drilled and tapped to M12X1.5: 12551587
You'll probably have to re-drill/tap it to 1/8" NPT unless you can find an adapter for your oil pressure line.
gasket is the same: 12553210 bolts for it are: 11588714
if it has an oil cooler on it, the plate bolts are too long, you'll either need to cut yours down or buy the new ones listed above.
Quick Reply: 6.0 oil pan question
