rounded out head Bolts...
Old 03-01-2009, 10:52 PM
04gtoBMXracer's Avatar
Default rounded out head Bolts...
Long story short my buddy let some jackass build his motor. He didn't torque the heads right and he blew a gasket. Now I find out that 2 15mm head bolts are rounded out and now I'm pissed. Any ideas how to get them out?ÿ
Old 03-01-2009, 10:56 PM
daniel6718's Avatar
6 sided 15 wont work? get a pic...
they make sockets that are tapered with teeth the wrong way..prolly what you need
Old 03-01-2009, 11:19 PM
I tried the 6 sided socket didn't work though. But I'm gonna try that other one, thanks man.
Old 03-02-2009, 01:03 AM
Anybody else got any tips?
Old 03-02-2009, 07:49 AM
sandking's Avatar
Go to Harbor Freight, buy two cheap open end wrenches, spot weld the them on the heads of the bolts, remove and throw away.
sandking's Avatar
Thats if you can get the wrench in there of course.
Old 03-02-2009, 07:53 AM
got-a-ls1's Avatar
weld nuts on top of them if you can... easiest fastest way
Old 03-02-2009, 07:56 AM
Droptopws6's Avatar
I dont think a wrench will work. I've had stripped lug nuts on my old 40 chevy and used the socket type tool as above. It worked pretty good, 19 bucks at summit racing.
Pic of head bolts, you mean the ones on the bottom or in the middle?
Old 03-02-2009, 09:13 AM
sandking's Avatar
Yeah, your right. Probably the welded nut on top like got-a-ls1 said would work best.
Old 03-02-2009, 11:10 AM
They are the ones in the middle.
Old 03-02-2009, 11:23 AM
SmokedOutZ28's Avatar
Sears has a socket set designed for stripped/rounded out bolts http://www.sears.com/shc/s/s_10153_1...stFilter=Brand If not I've found using a smaller size socket and hammering it on the bolt to get it out.
Old 03-02-2009, 11:31 AM
99LS6SS's Avatar
Drill in the middle of the bolt and us the extractor bit? I've broke bolts off before and thats how I did it. They make a special socket too that would probably be easier since they're torqued
Old 03-02-2009, 02:13 PM
Thanks for your input guys, I went and bought two cheap sockets and jb welded them on to the bolts. Came right off.
Old 03-02-2009, 04:02 PM
Grimes's Avatar
wow, jb weld saves the day yet again!
Old 03-02-2009, 07:57 PM
got-a-ls1's Avatar
amazed jb weld worked lol! i never been able to get that **** to harden to full strength no matter how i mix it... it doesnt like me.
Old 03-02-2009, 08:57 PM
tording99Z28's Avatar
I didn't figure JBweld would be strong enough to hold that. Thats awesome though. Glad you got it.
