Freeze plug help!
The following users liked this post:
Dopeydinerdog (09-06-2022)
I have 10mm, 3/8", and 5/16" hex heads and none of them fit the small freeze plugs on the driver's side of the block or the oil passage plugs. The 5/16" was the only one that went in but was too loose. The 10mm was too big.
So, I figure they are 9mm?
Ran into similar issue this weekend. Being a Datsun Z car shop, I have a decent selection of metric hardware on hand, so I found a bolt with the right sized head for the large brass core plug/block coolant drain.
Turns out it is 17mm as pointed out above. Found 10mmx1.25mm bolt with a 17mm head, then wanting a little more “engagement” with the soft brass, I added my last 10mmx1.25mm nut that takes a 17mm wrench, ran it up tight to the bolt, clocked the flats in phase and welded it to the bolt. I then took another 10mmx1.25 nut, this one takes a 14mm wrench, welded that on the end of the bolt. With this totally bubba, uber ugly “tool”, I was able to remove that stubborn brass plug. The block drain for the other bank takes an 8mm allen, already have one of those for a 3/8” ratchet.
Monday went down to Sears and bought a 17mm allen wrench. Will be cutting a length off of it and tacking that into a ½” drive 17mm socket for a dedicated LSx block drain tool.
Thanks BRAAPZ. 8mm and 17mm . I just ordered a Hex socket set from Harbor Freight with I think 8,9,10,12,14,17mm Hex, 7,8,11,13 square and 5/16 and 3/8 square heads.
Link:
http://www.harborfreight.com/cpi/cta...emnumber=94961
Link:
