Cam or Stall Converter
Well I would like to know what would be best for my next mod eithor a cam or stall converter. I can't afford both at the time and I would like to know which one would be the best for my application. My current setup is in my sig.
I want my car to continue to be streetable - it's my daily driver and I never race it at the strip, but i'll take any mod that will boost my hp.
From what i've been researching a tr224 114LSA & 3200 stall would be best for my car???
Best cam/stall combo depends on what you want out of the car. The 224 is a great all around street cam. The stall won't give you any more HP but it will make the car alot more fun to drive and is (imo) required before installing a cam 224 or larger. I would do the stall now, just research your cam choice now so you can go ahead and get a stall that will work well with it later once you have the funds for a cam.
Also it would be ok to just go for a small cam and still get a HP gain after a tune without the new heads, stall converter, or gears right??? Or is all or any of those 3 mods absolutely necessary when changing the cam.
im running a tr224 and Edge 3200 and it is an awesome combo. not the fastest thing out there but it impresses guys that run bigger cams when they ride shotgun....
Stall for sure. Definitly gonna feel it more than a cam. Go with a Vig if you can afford it. I had a Fuddle and it took a **** on me. Spent the money and got the Vig, no problems since.
Stall first most defiantly. I have a vig 3500 and it made my car feel like a totally different car. Not to loose on the street almost feels stock when you get used to it. I put in pacesetter LT's and the vig at the same time and knocked 8 tenths off my 1/4 ET I do believe the most gain was from the converter. Should be more than 8 tenths due to traction problems that I never had befor
STALL!! but like they said dont skimp on it. first time i bought a 2800 Dacco non lockup that costed 250 and it didnt even make it 10k before it took the new tranny out. i bought an Edge 3000 and loved it. stall first then cam
