421Ci LQ4 Build questions
Old 03-04-2009, 06:47 AM
vetteboyc5's Avatar
Default 421Ci LQ4 Build questions
Who all here has done this combo?
Basically is a 6.0L Iron block .030 over with a 4.125 stroke. Im interested in mainly what people think about the 4.125 stoke? I was planning to use large ammounts of spray on the engine that I build.
So lets talk about 4.125 stoke is it worth it?
Old 03-04-2009, 07:24 AM
briannutter's Avatar
Not good with this app. The 1.050 compression height piston lacks thick enough ring lands for big hits of spray
Old 03-04-2009, 08:07 AM
vetteboyc5's Avatar
So Am I stuck with a 408 only? I was thinking about 12:1 compression also Is that a issue? Also what is considered too much spray for the setup I listed
just difiniatively speaking here, There is also a 4.100 instead 4.125 crank. Does this make a difference for the better?
Old 03-04-2009, 08:16 AM
gator's 99TA's Avatar
if you are considering a large amount of spray, i would go to a 404-408" motor. get as much compression height on the piston and lowest ringland available. a stronger piston is much more valuable than extra stroke. stroke doesnt make power in comparison to nitrous and rpm
Old 03-04-2009, 12:14 PM
Our lands on the 1.050 stuff isn't bad at .250 top, .152 2nd because of the GFX rings (versus .295, .165 on the 1.110ch parts). If it were mine, I would run 4.125 with up to a 300 shot, but I'm also quick to acknowledge my own errors when I've pushed my stuff to far and chalk it up to mother nature. You'll have to take into account your tuning ability and willingness to always run Big octane if you're really going to press it..
Old 03-04-2009, 12:15 PM
ssick1's Avatar
why not go 414ci this motor is proven to handle some big shots
Old 03-04-2009, 04:15 PM
vetteboyc5's Avatar
Whats the specs on the "414"? In terms of making it.
Briannutter, What specifically are you talking about a type of piston or what are you refrencing, Im trying to follow you.
Old 03-04-2009, 09:54 PM
vetteboyc5's Avatar
bump Need more advice
Old 03-05-2009, 07:29 AM
We at Wiseco we have a line of 4.125 stroke pistons for various bores and compression ratios. The industry standard 1.5 (.060") and 1/16 (.062") rings leave a lot to be desired in terms of available land thickness. Our 1.2mm .047 GFX ring thickness gets us into a comfortable zone for a 250 or 300 shot. There are likely piston suppliers that can do you .043" ring stuff as well as customs. Skirt shape/taper is key with the iron block to avoid heavy skirt wear.
Old 03-05-2009, 10:06 AM
racer7088's Avatar
Thumbs up
What are large amounts and what heads do you have?
Old 03-06-2009, 05:28 AM
vetteboyc5's Avatar
Im thinking 250 Shot Max.
Heads havent been purchsed but im thinking a nice set of afr 225s or Texas speed has a new fully aftermarket casting 237Cc that looks promising. Im going to select all the parts when i officially find the road im going to take. I just got the block.
Old 03-08-2009, 12:25 PM
vetteboyc5's Avatar
bump I need some verdicts? I know itll hold spray, but How much? Heres The specs on the type of pistons Im looking into:
4.000,.030
4.125 stroke
1.050 1.5, 3mm
2618 Forged
FT+3cc
12.0 C/R with 66cc Heads
This is not a daily driver, and will be sprayed very occasionally
Old 03-08-2009, 01:50 PM
novaflash2002's Avatar
well you never know how long it will last with large amounts of no2. it depends on more than what you have listed. what injectors, fuel pump, induction, and most of all who and how will you car be tuned. will it be speed denisty? are all of the sharp spots in the combustion chamer gonna be polished down? what heads?
Old 03-08-2009, 01:56 PM
one fast zo6's Avatar
Default 421 iron
DON'T do it will suck oil like crazy,and really side load the cylinder wall.
BAD COMBO !!!!!!!!!!!
Old 03-08-2009, 02:11 PM
108dragon's Avatar
Sounds like some personal experience. lol
I have a set of 4.125 JE pistons I purchased used. They were used in a 4.000 stroke, 427 cid application. There is a LOT of skirt scoring on them. To this point I have not used them until I can determine the cause of the skirt scoring issue. Briannutter may have hit on the key. The thin lands and the way the piston is situated may cause a lot of lolling around of the unit in the cylinder bore in operation. One Fast Z06 may have experienced the effect of this in blowby, ring sealing issues, and increased oil consumption.
Old 03-08-2009, 05:24 PM
vetteboyc5's Avatar
Whats the possibilities of makeing 600HP na before spray with a 408 with good heads and a good cam, and supporting mods? It seems the 408 might be a safer option with only a 4.0 Stroke
Old 03-08-2009, 07:19 PM
thats a 13 ci inch differance, i dont think that it will matter much in hp, but the intital tq would be lower. it would not be too hard to make 600 flywheel hp.
Old 03-08-2009, 08:17 PM
KCFormula's Avatar
I've got the 4.125" crank combo. Although I don't spray mine its held up fine for years. (built in '03) W/ the sheetmetal intake mine made 630rwhp with LS6 heads but made it at over 8k rpm.
Old 03-09-2009, 12:15 AM
108dragon's Avatar
Wow! 8k rpm! I didn't think a 4.125" stroker would rev that high, let alone make those numbers there. What else did you do to that engine to get it to perform at that rpm?
Old 03-09-2009, 07:36 AM
skirt shape and cylinder length are the key to designing a piston that doesn't rock. do a couple searches on those subjects.
Quick Reply: 421Ci LQ4 Build questions
