least expensive good oil pump
who sells the lest expensive, yet quality oil pump? whether it be a ported LS6 one or just a real good quality pump. the cheapest one i've found so far is through TSP for 129.99 for a ported LS6 pump. thanks, Jess
Re: least expensive good oil pump
Go w/the TSP ported LS6 pump!!! i had some issues over the last few months w/my 98Z28 M6 losing oil pressure....installed the TSP and im running awesome oil pressure now quality product and good results...
before TSP oil pump 37-38psi at cold idle
after 60psi at cold idle
before pump at warm idle 22psi
after at warm idle 42psi
least expensive, yet quality? OEM. There were some issues with earlier pumps, but the current pumps are great unless you have something extreme in mind.
I think the main cause of pressure problems is the o-ring seal on the pump, so be careful when installing.
DEVOLK or ANYONE:
Can you kindly give me the phone number for TSP and what is the BEST OIL PUMP that money can buy, if i were to make a switch on my 427 C5R MTI motor, in order to get better oil pressure temps?
THANKS
THANKS
1(806)866-0734 is the # for Texas Speed and Performance....w/your combo, i think this TSP ported LS6 oil pump will do just fine...in fact, it sounds like u need it...hope this helps
