About to order my cam, have some questions
Im about to order a tr224 cam for my 1970 gto with a 2004 gto ls1 auto trans. This is going to be a daily driver. My question is 112 or 114lsa. I know a 114 is better for a dd. My question is--is the 112 idle much different than the 114? Is it to rough for a dd? After all its going into a muscle car. Does the 114 loose alot of its midrange? Do I have to have the car tuned? I know thats alot of questions but I always get great info from this site. Thanks
go 112 ur only running the 224 and not the 224r so u dont have the more aggresive lobes which will help. i have the 224r on a 112 and i dd my 2000 ta. my friend has a 224 on a 114 and it sounds sick still but not as lumpy. ur torque curve is going to move is a dif also. if u run the 112 ull make more down low which is better for a heavy street car
i would recomend te 112 just because it will sound a little better, and it will still be well behaved (unless you want your car to drive like a Buick). You cant go wrong either way. Good luck!!
LS1Tech Premium Sponsor
Don't rule out the 228R camshafts either. dyno testing constanly shows a solid 8hp gain over the 224 camshaft with very very little change to driveability. We've swapped 224s for 228s several times with good results.
http://www.texas-speed.com/shop/item...d=167&catid=44
Jason
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
The 112 lsa will be fine. It has a very very subtle chop to it. It should get tuned, but will run ok without it. Might surge a little and maybe try to die sometimes when you come to stop. Really should have a tune though when you go changing valve events like that.
