Stock Pushrods OK With Dual Springs?
I'm doing a H/C swap with a Torquer V.2 and some ported 853's that have patriot gold's on them. I had the heads milled .020 and I was told I could run a stock length pushrod. My question is, could I run the stock pushrods or would they not hold up well against the much stiffer dual springs?
Thanks,
Brandon
Thanks,
Brandon
well im installing the cam this weekend and i dont want to order pushrods untill i check it (i sure stock length is fine but if im getting new pushrods i should get the exact right ones) but i need my car to drive and can not have it down for a week or more
so how are stock pushrods with big cams and dual springs is the question, will i be able to go get the car tuned with them in (making several hard passes on the dyno?)
