5.3L or 6.0L Block
5.3L or 6.0L Block
Alright. Here's the deal. I've been doing tons of research for my upcoming build. I'm planning on using a Kenne Bell 2.8L blower as my power plant and I'm shooting for ~750-800whp on pump gas. I'm going to fully build the motor, but my question is "What block should I go with?" I've been given two options: 6.0L LQ9/LQ4 block OR a 5.3L LM7 block bored to 5.7L.
I've heard great things about both setups and have personally seen pretty high numbers on at least the 6.0L block. What do you guys think? Whichever block I choose is the full motor I will buy (ecu and all).
Thanks in advance,
Decker
Thanks in advance,
Decker
When you say a fully built moter do you mean a forged bottom end or a stock long block. A forged 6.0l bottom end gets my vote, more CI will be easier to make your power goals, Also if you have the $$$ you could get a stoker rotating assembly you would have a 402ci.
Thanks for advice guys. I will be building the bottom end with forged internals shooting for a 8.5-9.0 CR.
I know I'll have more displacement with the 6.0L block, but other than that are the any disadvantages to using the 5.3L block? Will it be able to handle the boost and power?
I'm honestly not too worried about displacement with power plant I've selected ($5k on a blower better do the job).
Thanks again!
Thanks again!
Why are you bumping this, everyone has been unanimous, which is very rare.
What information are you missing that you still need?
If you want to run the 5.3L block, just do it, just don't bore it .100 over and expect it to hold 600hp.
Are you looking for someone to tell you its OK to run the 5.3L block? You are not going to overpower any blocks.... unless you bore it .100 over
Buy the stupid 6.0L and just be done.
I don't see any posative to useing the 5.3 block. Punching it out so much is going weaken the block and make it compleatly unreliable! Just use the 6.0 block. I don't have a lot of time researching the 6.0 but (from what I have see) any tiny bit of knowledge about motors would tell you it just plain makes sence to go with the 6.0.
Go 6.0 man, why even waste your time w/ the same motor of lower displacement?
5.3 stroked = 5.7
6.0 stroked = 6.68 liters. Gee which will make more power? (408), hell, bore only mini stroke on a 6.0 will still net more displacement on the stock crank. (370)
5.3 stroked = 5.7
