Question..........LS6 "CNC" Heads + Intake:
Old 10-19-2003, 12:12 AM
HAWKMAN_'s Avatar
Default Question..........LS6 "CNC" Heads + Intake:
What kind of numbers are you folks seeing with LS6 "CNC" machined heads and LS6 intake on your LS1? Not the stock 2002 405hp set-up but the CNC heads. Anybody tried this set-up yet? Seriosly considering it. I figured it's got to be at good for at least 450 horses, am I close? Also, how much torque?
Old 10-19-2003, 07:46 AM
Restricted User
2001 Pewter WS6's Avatar
Default Re: Question..........LS6
I just put on a set of hand ported LS6 243 heads. I should make it to the track by next weekend. The flow numbers were really good so we will see.
Old 10-19-2003, 07:06 PM
HAWKMAN_'s Avatar
thnx for the reply, post some numbers and times if you get around to it.
Old 10-19-2003, 07:07 PM
HAWKMAN_'s Avatar
anyone else tried this combo yet?
Old 10-20-2003, 02:08 PM
LS1TECH Sponsor
JeremyF's Avatar
I have been able to make 461RWHP but that was with the best possible exh on a 03 ZO6 done by CNC. This was with a med cam and the car is unreal. ALMOST LIKE STK. I am a WD for them But we had some special things done to the heads to get that kind of power. But you will not be dissappointed. The owner has taken the car beyond the end of the speedo by an inch so my fair and totally resonable guess is that 210mph on stk 3.42 gears. PM me. I can nail it down and give you some more info.
Jeremy
