Need a site to print out good info on cam install please
Ok cams not going in for a while longer.Still got to get oil pump,double timing chain.Im looking for a site with great directions on it I can print out to read up on.Im 19 and Ill have my dad helping so I need good direction please.I will be using 918s and there retainers.Once agian thanks for any links you can give me.
Re: Need a site to print out good info on cam install please
Thank you very much do u think the oil pump needs changed car has 65000 miles on it?
If you have the stock '98 pump, then I personally would change it to a new OEM pump from GM. They are pretty cheap. Buy a few spare oil pump O-rings too just incase...sometimes those things like to get pinched up in there.
Changing the pump isnt definitly a "HAVE TO" item, but at that milage a new pump and chain are probably good.
